AllenJessup
Message 1 of 4 (250 Views)
Stitch composite surface
250 Views, 3 Replies
11-19-2013 11:33 AM
I created a Surface and pasted multiple Drefed Surfaces into that blank Surface. There was a small gap between each Surface. In the composite Surface those gaps still exist. I can insert points between the Surfaces or add lines. But that would be thousands of edits. Is there a way to stitch all the pasted Surfaces together?
I'm working in 2014.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Try adding a 'Show' boundary around the whole thing.
troma
Message 2 of 4 (245 Views)
Re: Stitch composite surface
11-19-2013 11:43 AM in reply to: AllenJessup
Credit where credit is due! Give kudos or accept as solution whenever you can.
AllenJessup
Message 3 of 4 (232 Views)
11-19-2013 12:08 PM in reply to: troma
Good deal. Worked like a charm (after a few minutes of processing :smileyvery-happy:)
Thank you!
Allen
troma
Message 4 of 4 (227 Views)
11-19-2013 12:20 PM in reply to: AllenJessup
Cool. Must be a biggie your making.
