I created a Surface and pasted multiple Drefed Surfaces into that blank Surface. There was a small gap between each Surface. In the composite Surface those gaps still exist. I can insert points between the Surfaces or add lines. But that would be thousands of edits. Is there a way to stitch all the pasted Surfaces together?
I'm working in 2014.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
Good deal. Worked like a charm (after a few minutes of processing )
Thank you!
Allen
Allen Jessup
Mark Green
