Civil 3D Forum
Steps in Surface
2 REPLIES 2
heritageengineering
266 Views, 2 Replies
Steps in Surface
I am having a problem of "steps" being modeled in my Surface.  I am using contours to generate the surface.  Instead of Civil 3D modeling a smooth straight surface from contour to contour, it is modeling a step like transition.  Any ideas as to why?
2 REPLIES 2
Can you post a screen cap or a DWG so we can see what you are seeing?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
autoMick
in reply to: Neilw_05
When you add polyline contours to a surface, there are options to minimise flat spots. You'll need to experiment, but I've found just turning on all the options does a reasonable job (see pic). The issue occurs when the triangle distance from vertex to vertex on the same contour is less than the distance between different contours.
Good luck
- Mick
Civil3d user in Australia since 2012.
Rail Community
