But if I do a distance from one contour perpendicular to the next contour
and do my slope by hand it calcs out correctly. My engineers are screaming
because of the extraneous little trianglulated spots, and in some cases I
have a large area that is shaded in except for a small triangle sliver that
is not. It makes no sense
Which leads to my next questions - IN THEORY - Slope analysis should be
measure perpendicularly to the contour (water running down hill). How come
it isn't doing this? Perhaps I'm just not grasping the concept here. I WISH
there was a way tha tI could take this steep slope and make it somthing
thatI could do a BPOLY on and hatch myself instead of have millions of
little triangles on the drawing. Another nice wishlist would be the ability
to say "I want to only see the steep slopes on areas that are laarger than
2000 square feet (or whatever number the municipality says they need to
see).
Thanks for the reply James.
Rick
wrote in message news:5526436@discussion.autodesk.com...
Two point slope labels do a simple rise over run across the entire distance.
Slope analysis looks at the centroid of each triangular face. You're
comparing oranges and tangerines. Sort of the same, but different once you
get at it.
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
Rick
coauthor Mastering Civil 3D 2012
I blog at http://simplycivil3d.wordpress.com
