I am using 2015 and when I do a Station Offset to Points report, it shows the Northing and Easting as shown...
BUT, when you create the report, they are not there...
This report has never displayed the Point's N/E, just the Pt# with Station/Offset, elev, & desc. What you see in the dialog is that actual point data for all points, it does not show the station/offset to the selected alignment. In order to include the N/E in the report, the report code would need to be modified.
@ishaq03 That is a .NET report so you would use Visual Studio to edit the C3DReports project located here: C:\ProgramData\Autodesk\C3D 2022\enu\Data\Reports\Net\Source
specifically these files will need editing:
PointsStaOffset_ExtractData.vb
ReportForm_PointsStaOffset.vb
Please any body guide me how to assign the center station on pipe. I now pipe start and end station available in default pipe properties table but I created number of pipes for ducts I want to show duct center station in pipe Table.
