Civil 3D Forum
Station Offset to Points Report Not Showing Northing/Easting
5 REPLIES 5
ToddRogers-WPM
956 Views, 5 Replies
I am using 2015 and when I do a Station Offset to Points report, it shows the Northing and Easting as shown...
BUT, when you create the report, they are not there...
Todd Rogers
5 REPLIES 5
Jeff_M
in reply to: ToddRogers-WPM
This report has never displayed the Point's N/E, just the Pt# with Station/Offset, elev, & desc. What you see in the dialog is that actual point data for all points, it does not show the station/offset to the selected alignment. In order to include the N/E in the report, the report code would need to be modified.
ishaq03
in reply to: Jeff_M
Please explain to us how to modify the station offset report to include northing easting
Jeff_M
in reply to: ishaq03
@ishaq03 That is a .NET report so you would use Visual Studio to edit the C3DReports project located here: C:\ProgramData\Autodesk\C3D 2022\enu\Data\Reports\Net\Source
specifically these files will need editing:
PointsStaOffset_ExtractData.vb
ReportForm_PointsStaOffset.vb
ToddRogers-WPM
Use Project Explorer
Todd Rogers
ishaq03
Please any body guide me how to assign the center station on pipe. I now pipe start and end station available in default pipe properties table but I created number of pipes for ducts I want to show duct center station in pipe Table.
Rail Community
