Id like to label Start Station= ##+### to End Station ##+###
can it be done with one label?
Your Name
Your Name
Solved by Joe-Bouza. Go to Solution.
Solved by klugb. Go to Solution.
Your Name
Your Name
Your Name
Your Name
@Joe-Bouza wrote:
Maybe I have it wrong but the material area is and end area in your table, no? Our client is looking for surface area from station A to Station B.
Then again I should consider a new format?
I know the quantity takeoff system doesn't compute volumes correctly, but does the earthwork portion work correctly? What I mean is, does it compute volumes correctly using the real 3d area of a surface or does it use just the 2d area?
