Joe-Bouza
Message 21 of 26 (64 Views)
Re: Station offset reference one label two stations
02-07-2014 05:36 AM in reply to: LisaPohlmeyer
But your suggestion is on point. the quantity is the quantity. Perhaps this format will be acceptable to the client.
By the way, I gave a material calc run for a look see and it out put a table of the last few hundred feet of alignment only, and I have sample lines from the beginning? any thoughts what that might be doing?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
LisaPohlmeyer
Message 22 of 26 (64 Views)
02-07-2014 05:39 AM in reply to: Joe-Bouza
Not off the top of my head. That's a tough one without looking at the dwg.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Joe-Bouza
Message 23 of 26 (63 Views)
02-07-2014 05:40 AM in reply to: LisaPohlmeyer
I know. Silly question anyway.
I'll dig into later today and let you know what I find out.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
LisaPohlmeyer
Message 24 of 26 (61 Views)
02-07-2014 05:43 AM in reply to: Joe-Bouza
Not sure I could get to it, but if you want to send me your email address, I'll create a dropbox folder for you & you can upload. Not sure of your workflow, but I could take a look.
Lpohlmeyer at wilco dot org
Lisa Pohlmeyer
Valued Mentor
engrtech
Message 25 of 26 (49 Views)
02-07-2014 06:06 AM in reply to: Joe-Bouza
Joe-Bouza wrote:
Maybe I have it wrong but the material area is and end area in your table, no? Our client is looking for surface area from station A to Station B.
Then again I should consider a new format?
I know the quantity takeoff system doesn't compute volumes correctly, but does the earthwork portion work correctly? What I mean is, does it compute volumes correctly using the real 3d area of a surface or does it use just the 2d area?
IDSP 2015
Windows 8.1 Pro 64-bit
8GB RAM
LisaPohlmeyer
Message 26 of 26 (48 Views)
02-07-2014 06:09 AM in reply to: engrtech
We're using 2012 and the quantities are done with Material Lists. The computations are correct for areas and volumes. We've found that we're within 3% upon project completion.
Lisa Pohlmeyer
