Civil 3D Forum
Station offset reference one label two stations
25 REPLIES 25
Message 1 of 26
Joe-Bouza
1269 Views, 25 Replies
Id like to label Start Station= ##+### to End Station ##+###
can it be done with one label?
Your Name
Your Name
25 REPLIES 25
Message 21 of 26
Joe-Bouza
in reply to: Lisa_Pohlmeyer
But your suggestion is on point. the quantity is the quantity. Perhaps this format will be acceptable to the client.
By the way, I gave a material calc run for a look see and it out put a table of the last few hundred feet of alignment only, and I have sample lines from the beginning? any thoughts what that might be doing?
Your Name
Your Name
Message 22 of 26
Lisa_Pohlmeyer
in reply to: Joe-Bouza
Not off the top of my head. That's a tough one without looking at the dwg.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 23 of 26
Joe-Bouza
I know. Silly question anyway.
I'll dig into later today and let you know what I find out.
Your Name
Your Name
Message 24 of 26
Lisa_Pohlmeyer
Not sure I could get to it, but if you want to send me your email address, I'll create a dropbox folder for you & you can upload. Not sure of your workflow, but I could take a look.
Lpohlmeyer at wilco dot org
Lisa Pohlmeyer
Civil 3D User
Message 25 of 26
Cadguru42
@Joe-Bouza wrote:
Maybe I have it wrong but the material area is and end area in your table, no? Our client is looking for surface area from station A to Station B.
Then again I should consider a new format?
I know the quantity takeoff system doesn't compute volumes correctly, but does the earthwork portion work correctly? What I mean is, does it compute volumes correctly using the real 3d area of a surface or does it use just the 2d area?
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 26 of 26
Lisa_Pohlmeyer
in reply to: Cadguru42
We're using 2012 and the quantities are done with Material Lists. The computations are correct for areas and volumes. We've found that we're within 3% upon project completion.
Lisa Pohlmeyer
Civil 3D User
Rail Community
