Civil 3D Forum
Station offset reference one label two stations
25 REPLIES 25
Message 1 of 26
Joe-Bouza
1293 Views, 25 Replies
Id like to label Start Station= ##+### to End Station ##+###
can it be done with one label?
Joe Bouza
25 REPLIES 25
Message 2 of 26
klugb
in reply to: Joe-Bouza
Yes sir.
Create one Alignment station-offset label and then add another using the reference text.
See image
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 3 of 26
Joe-Bouza
in reply to: klugb
Thanks Bruce
I must be doing something wrong because I added teh ref text but it give the same station. I sneed a sect pick to give me to ##+### sot the finished product should say
start station #+### to end station @+@@@; two different station same base line
Joe Bouza
Message 4 of 26
ccoles
If I understand your question, you want to label a station range with a start station and an end station of the same alignment on a single alignment label. This is possible with an alignment line label. But, I believe it would either need to be a single point-to-point line segment, not a complex line section with multiple PIs and curves, or you'd need to create a sub-alignment that only extends from your start to end range. Then the line label can use the 'Alignment Start Station' and 'Alignment End Station' tags to get what you need.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Message 5 of 26
klugb
No not you. I misread your question. I was thinking you wanted one location labeled with 2 different alignments station/offset.
My bad.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 6 of 26
Jay_B
Joe,
Try adding the "Alignment Start Station" and "Alignment End Station" properties to the label.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 26
Joe-Bouza
in reply to: Jay_B
Sorry for misleading you Jay. I'm looking for two arbitray point on the same base line
Joe Bouza
Message 8 of 26
Jay_B
Ah, now I get what your after Pick 2 points anywhere along the alignment and label start / stop stations.
C3D 2018.1
C3D 2016 SP4
Message 9 of 26
Joe-Bouza
in reply to: ccoles
you have it correct, but I trying to compose the label to use in a table. Something like this: I know its bass ackwards but I have the rehab job that wants tables of qty similar to this.  in my plan presentation I typicaly show a hatch pattern in the widen areas. Well I decided to get smart and my curbs are alignments and my sawcut lines are alignments, so I put them in a site and viola automatic/ dynamic hatch.
I knew I couldnt get the stations in a parcel table so I thought station lables can ref the parcels, so I composed the label to be dragged int to table outline, and I'm looking to get the end station in the same label. the other field were easy parcel properties with expressions.
Joe Bouza
Message 10 of 26
Joe-Bouza
For now I settled on two labels. its not my favorite but full steam ahead .. **** the torpedoes!
Joe Bouza
Message 11 of 26
klugb
Is this what you want?
The objects are dynamically linked to the table.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 12 of 26
Joe-Bouza
in reply to: klugb
Yes! can it inlude a parcel area too?
How is it done?
Joe Bouza
Message 13 of 26
klugb
Not sure about an area? The table looked similar to a table we use for pipe callouts. So I just drew pipes randomly and inserted a modified table. You could draw pipes where you want the table info.
Attached is the drawing.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 14 of 26
Joe-Bouza
in reply to: klugb
Thanks. thats a good idea I'll keep in mind for the future
Joe Bouza
Message 15 of 26
Joe-Bouza
in reply to: klugb
Excellent!
Althought I cannot directly get parcel data into a pipe table, I can get it in a label style and compose as needed.
Joe Bouza
Message 16 of 26
Lisa_Pohlmeyer
Joe, Your corridor materials table won't give you what you want?
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 17 of 26
Joe-Bouza
in reply to: Lisa_Pohlmeyer
Lisa
Not sure? the sample is looking for surface area station to station
Joe Bouza
Message 18 of 26
Lisa_Pohlmeyer
These are from our materials & earthworks tables, info from sample lines. Maybe I'm just not getting what you're asking.
Lisa Pohlmeyer
Civil 3D User
Message 19 of 26
Joe-Bouza
Maybe I have it wrong but the material area is and end area in your table, no? Our client is looking for surface area from station A to Station B.
Then again I should consider a new format?
Joe Bouza
Message 20 of 26
Lisa_Pohlmeyer
Ah, gotcha. Yes, it is the end area. See, I didn't understand. C'est la vie!
Lisa
Lisa Pohlmeyer
Williamson County Dept. of Infrastructure
direct: 512-943-3364
main: 512-943-3330
Lisa Pohlmeyer
Civil 3D User
Rail Community
