I'm setting up a new template to match an new client's requirements. I have an alignment that I'm trying to station. The alignment is 905 feet long and is draw as such. My starting station is 10+00. Why am I getting the end station to be 10+75.42? (75.42 x 12 = 905). What obvious setting am I missing???
Solved by Jay_B. Go to Solution.
Sounds like your units may be set to INCHES.
Drawing Settings > Units and Zone Tab > Drawing Units:
shamilton wrote:I'm setting up a new template to match an new client's requirements.
Since Inches isn't a standard option within the templates supplied with Civil 3D, you may want to review the source of the template you're building.
Feet and Meters are the standard Drawing Units: choices.
However, the drawing units will report Inches when an architectural dwg is opened in Civil 3d.
