I am having a problem where my station labels are the correct size in model space, but when I switch to paper space they stay really small. I think it is a mm/m problem but can't seem to find a solution in the properties of the station label group. If I type a piece of mtext it works fine. Any suggestions out there? It's is driving me crazy.
Thank You
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/how-to-edit-station-labels/td-p/3389891
Also see:
Profile labels are not acting as ?
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Profile-labels-are-not-acting-as/m-p/3378339#M172689
