I can't find the standard tool bar on C3D 2011 since was installed. How can I get it to show?
Thanks.
Neptuno8881
Solved by Neptuno8881. Go to Solution.
Solved by rnoyes. Go to Solution.
Type CUI & go to Parcial CUIs & expand ACAD, toolbars & it's hiding there.
highlight your workspace & then click "customize workspace" above the right side pane in CUI. The contents of your workspace will turn blue which means you are in edit mode. now go back to the left pane & there will be a check box where you found that toolbar and you can check it on.
Another option if you dont want to open the cui is to right click in the dark grey area, select Autocad, then select the "standard" toolbar.
