Active Contributor
wvyhonsky
Message 1 of 5 (196 Views)
Standard text style when adding labels
196 Views, 4 Replies
11-16-2011 08:00 AM
When I drag and drop a label style from another drawing, the text style of the label changes to STANDARD.
Is there a setting that is overiding the text style from the original label?
Thanks!!
Civil3d2012, W7 64
Valued Contributor
MichaelMerlino7407
Message 2 of 5 (185 Views)
Re: Standard text style when adding labels
11-16-2011 09:27 AM in reply to: wvyhonsky
Verify that the same text style name actually exists in the drawing you are pasting to.
Michael Merlino
Civil Engineering Technician / "CAD Manager"
SAN JOSE, CA, USA
Active Contributor
wvyhonsky
Message 3 of 5 (179 Views)
11-16-2011 10:10 AM in reply to: MichaelMerlino7407
Yes the text styles did exist.  Anyway, when I went to test again, I see that it is not a label style that it was happening to, but the 'profile view style'.  All of the styles on the Title Annotation, Horiz. Axis, Vertical Axis, etc. are going to STANDARD
BrianHailey
Message 4 of 5 (174 Views)
11-16-2011 10:26 AM in reply to: wvyhonsky
If you are using 2012, do you get the same result if you import styles using the new tools?
Brian Hailey
CAD-1.com
My Blog
Active Contributor
wvyhonsky
Message 5 of 5 (168 Views)
11-16-2011 10:38 AM in reply to: BrianHailey
That worked fine.  I guess I will use that option for now on.
Thanks!
