C3D 2013, all updates.
Using SSM, and I have added some fields using the process shown in this image to obtain the sheet number of a particular sheet.
I opened a drawing today and noticed ALL of these fields were displaying as ##. (RegenAll did not update the fields, and if I tried to edit one of them, the field category said "Unknown")
Nothing had changed with our files or system that should have caused this. By chance, I happened to notice that I had more than one sheet set open in the SSM, so I closed all of them except the sheet set to which this sheet belongs. Then did another RegenAll and voila.... the fields updated correctly.
Can you really not have multiple sheet sets open in the SSM in order for fields like this to work? I would have thought I would have run across this before. I'll do some more testing, and if anyone has time to test this out too, it would be appreciated.
TIA.
