Distinguished Contributor
3 Kudos
Post 1 of 8
Spot Elevation - Distance between PVI's?
441 Views, 7 Replies
10-22-2011 12:03 PM
Im using Civil 3D 2012.
I want to show the distance between Profile PVI's on a Surface Spot Elevation.
Possible?
Yes. use a featureline with a label style the shows the end elevations and distance between. Set the FL style to NoShow or NoPlot
327 Kudos
Post 2 of 8
Re: Spot Elevation - Distance between PVI's?
10-22-2011 02:06 PM in reply to: kevinjackman
You can add profile data to alignment labels that show stations. Some finessing the style may get the desired results.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
3 Kudos
Post 3 of 8
10-23-2011 08:17 AM in reply to: kevinjackman
I can add profile data to a spot elevation label without issue but i can't calculate the length between pvi's.
3 Kudos
Post 4 of 8
11-01-2011 08:00 AM in reply to: kevinjackman
Any of you label experts out there have the answer?
327 Kudos
Post 5 of 8
11-01-2011 09:15 AM in reply to: kevinjackman
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
3 Kudos
Post 6 of 8
11-01-2011 10:50 AM in reply to: Joe-Bouza
Thanks Joe.
327 Kudos
Post 7 of 8
11-01-2011 11:25 AM in reply to: kevinjackman
HTH. Sometimes it takes a fresh look, and pulling out that stubby phillips head screwdriver the hardly gets used. :smileywink:
I see you also got the grade in there, nice.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
327 Kudos
Post 8 of 8
11-01-2011 11:27 AM in reply to: kevinjackman
another way I have used is to create a FL from an alignmentent. and you can use alignment label styles to label pgl in plan
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
