Im using Civil 3D 2012.
I want to show the distance between Profile PVI's on a Surface Spot Elevation.
Possible?
Solved by Joe-Bouza. Go to Solution.
You can add profile data to alignment labels that show stations. Some finessing the style may get the desired results.
Yes. use a featureline with a label style the shows the end elevations and distance between. Set the FL style to NoShow or NoPlot
HTH. Sometimes it takes a fresh look, and pulling out that stubby phillips head screwdriver the hardly gets used.
I see you also got the grade in there, nice.
another way I have used is to create a FL from an alignmentent. and you can use alignment label styles to label pgl in plan
