Civil 3D Forum
Spot Coordiantes and Elevations
2 REPLIES 2
trynders
301 Views, 2 Replies
I am creating a water line drawing.  The owner wants all angle points to be labeled with northing, easting ccoordiantes and an invert elevation.  I have created a surface spot label to place the coordiantes and surface elevation.  Is there a way to have it read the surface and subtract say 42 inches?
2 REPLIES 2
Jay_B
in reply to: trynders
Yes using an expression in the Surface Spot Elevation Label Style, name the expression such as Surface-3.5, create the expression such as {Surface Elevation}-3.5
Go to the Layout tab of Label Style Composer for Surface Style and select Surface-3.5 (or whatever name you chose) to apply the expression to label.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
trynders
in reply to: Jay_B
Perfect.  Thanks so much!
Rail Community
