I'm working on a parking lot expansion that is built into a grassed hill. The existing parking lot area needs to be excavated down for proposed granular fill. I only have ONE existing ground surface and have created ONE grading surface for the entire parking lot and now my boss would like me to sepearted the volume calculations between the "hill area" and the "existing parking lot area" (for tender purposes). How would one go about doing this? I hope all this makes sense. I've attached a sketch to give you some what of an idea.
Thanks.
Solved by Jeff_M. Go to Solution.
Solved by Joe-Bouza. Go to Solution.
Joe Bouza
Dennis,
Eric Colburn has a pretty good video on Volume Calculations. It's 4-1/2 minutes, and cuts to the chase:
http://www.youtube.com/watch?v=Ya5yJ_-phIM
I gotta know, what are "tender purposes"?
Dave
Dave Stoll
Las Vegas, Nevada
Thanks for the feedback but maybe I wasn't to clear on what I was asking because I know how to compare 2 surfaces from one another, also, how to create surface banding. What my boss would like is 2 SEPERATED volumes. 1. red zone on sketch (All Gravel) 2. blue zone on sketch (All Dirt). The reason why he wants 2, is so the contractor who is bidding the job can price the areas seperately because excavating compacted gravel is more time consuming then excavating loose dirt. What I am having difficulty with is, I have 1 parking lot grading surface that needs to split along the boundary of gravel and dirt.
Also, A tender is a package of work or drawings being distributed to contractors so they can bid a job.
Geeze! I didn't see the icon sorry. Thanks a lot Jeff and Joe! Worked great.
