I have created a split profile - but can it be adjusted such that there is a gap at the split vertical axis i..e. so I can create 2 viewports easily??
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
That would be nice, but you have to create multiple profile views to accomplish this.
Thanks - I couldn't get the Multiple profile wizard to work so I just copied the profile and adjusted the chainage range on each and that was ok for the purpose....
