Civil 3D Forum
split points on a feature line
5 REPLIES 5
wbrustle
1094 Views, 5 Replies
I am drawing a few feature lines within my surface and it is creating split points.....not even sure how they are created and how do I get rid of them....is there a way? I read a little about them and what I have read so far indicates that it is a point where two feature lines cross? I don't have another feature line created anywhere near this one.
5 REPLIES 5
castled071049
in reply to: wbrustle
What do you mean by "split points"? Maybe a screen shot or something to clarify?
troma
Is there a grading crossing the feature line?
Mark Green
Working on Civil 3D in Canada
Jeff_M
If the featurelines cross any other featurelines, alignments, or parcels in the same Site, you will get these uneditable points.
AllenJessup
If overlaps are your problem. This might be helpful.
AeccFindSiteOverlaps
Start with this command, which will check for overlapping alignments, feature lines, and lot lines in a Site. A dialog box will be displayed, prompting you to select the Site to check. This command will mark any overlapping locations found with AutoCAD points, placed on the layer _OVERLAPPING_SEGMENT_LOCATIONS.
Note: To see the AutoCAD points better, you can use the DDPTYPE command to change the visibility settings if necessary, which will force a Regen. However, in cases with unstable Gradings or behavior a Regen may result in a crash.
Allen Jessup
Allen Jessup
CAD Manager - Designer
wbrustle
in reply to: AllenJessup
yes.....I believe these points along my feature line may have crossed the alignment I was using in the same site, which most likely caused the problem...thanks so much...I will watch that from now on.
Rail Community
