troma
Message 1 of 6 (329 Views)
Split drawing in half—but using Sheet Sets
329 Views, 5 Replies
01-25-2013 07:02 AM
I've seen comments from others that they use a 'one sheet per drawing' policy to avoid conflicts of overlapping text in modelspace, to allow more drafters to work on a project and to cut down on file size and corruption.  We have typically had two or three sheets in a drawing, depending on the length of a street.
For this project, when setting it up, I was considering changing our approach towards one sheet per drawing.  Then I thought to myself "Hey, no problem, I can set it up as usual and split them later if I want to."  The idea being that with everything xreffed & dreffed it's no problem to SAVEAS and delete one layout out ot this drawing and delete the other out of the other drawing.  Hey presto I'm at a one sheet per drawing situation.  But there was one thing I didn't think about: the sheet set manager.
So now I was thinking of splitting up a drawing.  I have sheet number, title, description set up.  I have callout blocks on both sheets referencing each other and referencing other drawings, and I have callouts in other drawings referencing these sheets.
What do you think?  Have I snookered myself?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Every sheet has a target dwg and target layout. I think you can edit this in the sheet set property for each sheet. No computer in front of me right now but that's where I'd check first.
*Pro
dgordon
Message 2 of 6 (317 Views)
Re: Split drawing in half—but using Sheet Sets
01-25-2013 08:19 AM in reply to: troma
sheet manager is pretty flexible when it comes to renaming sheets.   I wouldn't worry about that.   That being said, it's probably just easier when running plan production to set it up as 1 layout per sheet.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
troma
Message 3 of 6 (307 Views)
01-25-2013 08:39 AM in reply to: dgordon
Not sure if I explained myself the best.
"sheet manager is pretty flexible when it comes to renaming sheets."
That's ok, but I don't need to rename a sheet exactly.  I will need to point the existing data within the sheet set to a different sheet, in a different drawing file.
"it's probably just easier when running plan production to set it up as 1 layout per sheet."
I don't follow.  What's plan production?  What am I running?  What am I setting up?  Do you mean 1 layout per drawing?  Or what am I missing?
Thanks for the help.  I know that I'm not as deep into sheet sets as many others, so I appreciate any advice.  Currently my only idea is to delete the sheet from the set and import the new sheet.  Then I have to reenter all the data and redo the callouts in any drawing that is refferencing the sheet.
mathewk
Message 4 of 6 (297 Views)
01-25-2013 09:43 AM in reply to: troma
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
troma
Message 5 of 6 (294 Views)
01-25-2013 09:46 AM in reply to: mathewk
Hey, that looks promising!
I'll let you know how it goes (if it goes).
Thanks.
troma
Message 6 of 6 (233 Views)
01-28-2013 10:17 AM in reply to: mathewk
Thanks Matt, worked like a charm!
