OK, weird question.....
Does anyone know of a way to create a windows shortcut to a drawing that opens a specific Paperspace Layout?
For example, I have a drawing located in a Windos folder called 'Appraisal Maps', the drawing contains 2 paperspace layouts, one of which is named Show Me Stakes. I would like to have a Windows shortcut of the drawing inside of a Windows folder called 'Staking-Show Me', so that when I double click the drawing it will open up and automatically switch to the proper paperspace layout.
I am wanting this for two reason, 1) so that we do not create multiple drawings and actually use the power of autocad layout tabs and layer management. 2) so that when management opens up the drawing it goes directly to the proper layout minimizing their head scratching as to what is going on.
Chris M. Davis
If I'm understanding correctly Sheet Set Manager would work great for this.
Jay_B, thanks for the reply...I am looking for a windows shortcut solution outside of autocad. Unless I can create shortcuts of the sheet manager. I have attached an image. As you can see I have the shortcut of the drawing in the folder, and I was curious if inside the properties of that shortcut I could specify the layout tab. Much like the autocad program shortcuts where you could specifiy a specific *.arg file.
Chris
This link lists all of the startup switches that are available with AutoCAD: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2894625&linkID=9240617
I don't see anything there for specifying a layout. The view option may work, but you will have to assign a named view to the layout. If that does not work you may be able to load a simple script file that runs the LAYOUT command with the Set option.
So is the goal for this always to open the same single layout within that drawing at startup?
If so why not create an arg profile that has the QNEW variable set to the drawing (renaming extension to dwt) containing the Layout?
Then put that arg in a Profile switch in the desktop icon & it would always launch cad using that dwt.
I'm still not quite understanding why this needs to be done & how it's to be used?
Here is a link for more switches:
http://www.hyperpics.com/downloads/resources/customization/general/AutoCAD%20Icon%20Switch.pdf
Bill
PS: Layout is included
Joe Bouza
