Civil 3D Forum
special lines
7 REPLIES 7
Message 1 of 8
503 Views, 7 Replies
special lines
Is there a special line command like in LD 2004 under "Lines and Curves" to draw lines with text inserted in the line?
7 REPLIES 7
Message 2 of 8
Nope.
Jason Hickey
Civil 3D 2007, SP2
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
Message 3 of 8
Bummer. Thanks for the info.
Message 4 of 8
but try this
http://civil3drocks.blogspot.com/2006/06/label-style-for-calling-out-elevation.html
Dana Breig Probert
www.civil3d.com
Civil 3D 2007 SP2
AMD Athlon 64 X2 Dual Core 2.01 GHz
2GB RAM, 256 MB ATI FireGL V5200
"Jason Hickey" wrote in message
news:5326292@discussion.autodesk.com...
Nope.
Jason Hickey
Civil 3D 2007, SP2
Dell Precision M70
www.civil3d.com
Message 5 of 8
Have you tried the "new" linetypes with text that you can do with AutoCAD?
They work pretty well, and then don't litter your drawing with lots of
little lines and text.
Cheers,
Peter Funk
Autodesk, Inc.
Message 6 of 8
Where do I access this? Is it a command or a linetype setting?
Message 7 of 8
You can either change the linetype of a layer, or the line type of a
line/arc/polyline. In the standard AutoCAD linetype file you'll find a
couple of fence lines and a gas line. If you need to add some more, it is
pretty simple. The scale of the text/symbol is set with the ltscale.
Peter Funk
Autodesk, Inc.
Message 8 of 8
tscheevel
The following takes you to a page of how-to articles. Look for "Applying Custumization: Making complex Linetypes" Part 1 and Part 2.
http://usa.autodesk.com/adsk/servlet/autoindex?siteID=123112&id=2253435&linkID=2475176
Rail Community
