In LDD, you could create a special ditch profile and then attach that ditch profile to a centerline alignment/profile in the same manner you attached a transition profile or alignment. In C3D 2007, there doesn't appear to be an obvious (or as simple) way to do that. I've seen some info pointing to some of the slope assemblies, but they seem to be more complicated than the LDD format, which intuitively tells me I'm missing something. Is there a simple way to attach a special ditch grade? Thanks.
