I've got a few questions regarding Civil 3D that you guys could likely help out with:
1. If I'm working on a project, and define a particular way of labeling profiles that works well for our company, how do I make that label style accessible to me later when I'm working on another project? Is there a style import function, or do I have to redefine it each time?
I suppose I could define them once in a template, but is there a way to import these styles between drawings?
Does the Vault provide any functionality for importing/storing styles?
2. If I have an existing ground surface and define a landfill by creating a rectangle, at an elevation above the ground surface and grade down to the surface at 4:1; then I define the second phase of the landfill which will partially overlap the first phase. Do I have to merge the first phase and existing ground before the grading will work, or will it grade to both the grading of the first phase and the existing surface?
It seems to me that it would be much easier (from a design perspective) to avoiding having to merge the EG & Phase 1 in order to work on Phase 2. Design iterations being as they are, it'd be great not to have to do this.
Thanks for your info, it's much appreciated.
Reply Syntax?
Command (Uppercase): TRIM, Variable (Italicized): MSLTSCALE, Civil 3D Object (Within brackets): [SITE]
If this solves your issue or answers your question then please hit the KUDO button or mark as an ACCEPTED SOLUTION!
Please support my Idea to revert the forum format to the old one: https://forums.autodesk.com/t5/community-ideas/revert-to-old-forum-layout/idi-p/7917987
