Civil 3D Forum
Some question, PLEASE HELPPP
3 REPLIES 3
877 Views, 3 Replies
Q\ What does a Parcel Style assign n the Display tab?
a) The size of the Parcel
b) How the line segments are labelled for the Parcel
c) The layer whre Parcel segments are assigned
d) The label text for area and name
I think that b correct answer
Q\ The Add Label dialog box is used to
a) Create static text describing what you want to label
b) Add or change labels during Parcel creation
c) Add or change labels after Parcel creation
d) Is used to make new label styles
I think that a correct answer
Q\ The Prospector tab is used to
a) Connect GIS data from multiple locations
b) Set layers for AEC objects
c) Gives access to information about and a list of AEC objects in teh drawing
d) Chooses the workspace where you want to work
I think that c correct answer
Q\ If you are trying to get at a particular object in you r drawing (for example - to select an alignment) but something else keeps "getting in the way" by being selected you can
(select all that apply)
a) Right click when the "bad" object(s) (not the one you want to select) is selected and choose Draw Order
b) Zoom in to be able to select more accurately
c) Use Prospector to make your selection
d) Turn off, or freeze, the layer containing the "bad" object(s) (not the one you want to select)
please help me, i'm not sure that my answers are correct .
3 REPLIES 3
antoniovinci
In my opinion, all right but the fourth one: I'd answer "B", sir.
in reply to: antoniovinci
the last question possible to be more than one choice
MarySeufert
For question 1, 'B' is not the right answer.
For question 2, 'A' is not the right answer. Labels are not static text.
For question 4, all of them could be seen as a way to select an alignment (or get to it). But if this test is about how to use C3D to accomplish a task, 'C' would be the right answer.
'C's ace this test.Smiley LOL
EXPERT ELITE MEMBER
Rail Community
