Solved by AllenJessup. Go to Solution.
That button James was referring to toggled the OSNAPZ sysvar on/off, nothing more. Setting this manually by typing it in should be all you need do. OSNAPZ does not have any effect when using grips to snap, only when using ObjectSnaps (node, endp, near, etc.).
Have you tried setting your point styles to use 0 elevation? This still keeps the CogoPoint elevation, but the symbol/marker is set to the elevation specified in the style...usually this is 0.
@mcloughlin wrote:
"OSNAPZ" does not accomplish the task of drawing flat polylines to elevated point nodes. Thanks.
The button you mention didn't make it into later releases. As Jeff mentioned. It only toggled OSNAPZ. If you say that doesn't work then the button wouldn't work either.
When you say it doesn't accomplish the task. What results do you see?
Why are you unable to leave you flattened to an insertion of 0 and use the Point Object transparent command ( 'PO ) to grab the elevation when needed.
Allen Jessup
CAD Manager - Designer
To follow up with Jeff's statement:
Once you've enabled OSNAPZ when you snap to a point, it will be snapped to the x&y of that point but the z value will be taken from the defaul elevation of the current ucs. You can change that default elevation by typing ELEV. You will be prompted for default elevation (set it as desired) then a default thickness (typically, this should be set to 0).
Don Ireland
Engineering Design Technician
I tested it. When I insert the points with their markers at the point elevation and draw a polyline. The polyline is at the elevation of the first point. When I set OSNAPZ to 1 with ELEV set to 0. The polylne is at 0. This holds for 3D polylines as well following the elevation of each node with OSNAP at 0 and all nodes at 0 when OSNAP is 1.
If you have points at Elevation. A way to start a polyline at 0 would be to use the Point Filter of .XY and provide the 0 elevation. With a 3D polyline you would have to use the .XY filter for every node picked. .XY can be typed from the keyboard or picked from the rt-clk menu.
Allen
Allen Jessup
