Solved by Adam_Farnsworth. Go to Solution.
I have the same problem in Civil 3d 2010. When I create a surface that is not very complicated (only defined by 200 points or so) and try to label the contours, about 5 seconds elapses between clicking on the contour line to label and the actual contour label disappearing. Times that by 40-50 contour labels, and time starts to add up just to label contours.
I am also running Civil 3D in Windows 7, but had this same problem on XP. The time to label a contour goes up dramatically depending on the surface size. The last project I worked on had a relatively large surface, and it took 30 minutes just to add contour labels to the existing and proposed surface.
I think I've figured out a solution. In my surface style, I was using Contour Smoothing. (Surface Style > Contours Tab > Contour Smoothing > Smooth Contours > True). When I turned this off (set it to False), it sped up my contour labeling considerably.
Let me know if that works for you as well 🙂
--Adam
Rock on! 😄
