Civil 3D Forum
Slope Map Display
8 REPLIES 8
Message 1 of 9
444 Views, 8 Replies
Slope Map Display
The undefined areas of a slope map now have a hatch to them and are plotting black. This map was created a month ago in 2012 without issues, upgraded to 2014 and now the undefined range has hatch!
Please see the attached image
Any ideas?
8 REPLIES 8
Message 2 of 9
BrianHailey
I just noticed this last week myself. I'm planning on submitting a support request with Autodesk.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 9
ToddRogers-WPM
This is a known issue.  Autodesk is fully aware of this.  However, I have not tried it after the install of Hotfix 1.  Hotfix 1 README states...
Surface
  • An issue that caused an error when switching between layouts with the level of detail display enabled has been resolved.
  • Adding, deleting, and re-adding a point file to a surface definition no longer causes the application to close unexpectedly.
  • Surface analysis data is now retained as expected after rebuilding the surface.
Todd Rogers
Message 4 of 9
The hotfix didn't address this.
GEI Consultants
My Civil 3D Blog
Message 5 of 9
Good to know.
Todd Rogers
Message 6 of 9
Great, I love the "known issues"
I suppose until a Service Pack we are SOL???
I did committ the cardinal sin and explode the slope map surface, the non-hatched black area does disapear.
Message 7 of 9
tcorey
A better option than exploding would be to extract objects.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 8 of 9
CADvisers
I know this doesn't fix the problem.  But until Autodesk fixes this issue, here's my "workaround."
And it at least keeps the surface display intact, rather than having to extract hatches.
Have the surface on a layer with color 255 and set the Transparency of the layer to something greater than 60.
Make sure to Plot with Transparecy checked in the plot dialog
Your colored slope ranges will be plotted with their assigned transparent colors while the rest, or undefined range will plot a very light greyscale that shouldnt be too obtrusive.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
Message 9 of 9
jmayo-EE
in reply to: CADvisers
...and if the gray is bothersome just edit the stb or ctb and give color 255 (or any color of your choice) a screening of zero.
John Mayo
Rail Community
