rkmcswain
Message 1 of 14 (1,755 Views)
Slope labels for feature lines projected to profile
1755 Views, 13 Replies
09-21-2011 02:41 PM
C3D2011
Say you have a feature line in plan view and you project it to profile view.
Is there a way to label the true slope of the projected feature line segments in profile?
The profile view depth labels are not accurate since it's simply calculating the length from station to station in profile.
...and of course this does not correspond to the true segment length since the feature line is not parallel to the alignment.
Joe-Bouza
Message 2 of 14 (1,741 Views)
Re: Slope labels for feature lines projected to profile
09-22-2011 05:24 AM in reply to: rkmcswain
If you project anything to a profile view that is offset (and/or not parallel) to the alignment the true grade can't be labeled. Just like the outside and inside eop will not have the same true grade as the PGL.
And to do so with the profile view stationing would be equally incorrect.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
rkmcswain
Message 3 of 14 (1,737 Views)
09-22-2011 06:04 AM in reply to: Joe-Bouza
Joe-Bouza wrote:
If you project anything to a profile view that is offset (and/or not parallel) to the alignment the true grade can't be labeled. .
When you say "can't be labeled", I'm assume what you are saying is that this is missing functionality, because obviously there is no reason it can't be done. The true grade is known, there just isn't a command to make it happen......
Joe-Bouza
Message 4 of 14 (1,732 Views)
09-22-2011 11:32 AM in reply to: rkmcswain
That's not exactly what I'm saying.
If you have a profile view along the center line and the grade is 2% and you have a curve from station pc1+25  to pt2+00 (assuming no SE) the grade of the inside and outside curve will not be 2% but some other value x% (due to the arc length). If you project either eop to the profile they will project to station 1+25 and 2+00 respectively. The functionality to label is there but each curve is actually shorter or longer than 75 feet, but the end points will be at the correct elevation, so if you place the real grade on them the point can be argued that E2-E1/ .75 does not equal x%.
I believe this is why the software does not label SI profiles; it would be a lie.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
rkmcswain
Message 5 of 14 (1,726 Views)
09-22-2011 12:23 PM in reply to: Joe-Bouza
We are on a different wavelength here....
I understand the whole thing about true length, etc. Sorry, I tried to make that clear in my initial post....
My point is that C3D *knows* the true length of any feature line segment, and it knows the elevations at each end point, and so by definition, it knows the true grade - which is easily found in the C3D table below.
So yes, I know the *representation* of any given segment in the profile will not be accurate - but I'm not interested in it labeling segments on how they appear, just labeling the true grade.....hence my conclusion that this is missing functionality.
Thanks.
Joe-Bouza
Message 6 of 14 (1,721 Views)
09-22-2011 12:55 PM in reply to: rkmcswain
:smileywink: I think we are on the same wave length. I think the functionality is not there due to the true length conundrum
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
rkmcswain
Message 7 of 14 (1,718 Views)
09-22-2011 01:04 PM in reply to: Joe-Bouza
So what choice is there than manually placing text/mtext in the profile view     :smileymad:
Seems as if there would be more people needing this functionality...
jbear0000
Message 8 of 14 (1,622 Views)
12-15-2011 08:50 AM in reply to: rkmcswain
Did you ever find a way to do this? I also need to add slope labels to projected feature lines.
rkmcswain
Message 9 of 14 (1,517 Views)
03-16-2012 08:13 AM in reply to: jbear0000
No, I have not.
jbear0000
Message 10 of 14 (1,513 Views)
03-16-2012 09:04 AM in reply to: rkmcswain
My solution for this was to project the feature lines, then create a new profile line that follows along those projected feature lines. I then set the style for that new profile line to be a non-display style and then I have slope labels on my projected feature lines. In the areas between the projected feature lines I simply delete the slope labels I don't need.
