I'm getting the rotated viewcube annoyance in 2013 but I'm aware that removing GEOGRAPHICLOCATION solves it (note to AutoDesk - please stop putting in pointless new features i.e. Cloud(?) and just make sure the basics work....)
I have done this and resaved my template but when starting a new drawing (from the template) the ViewCube is rotated again.
Is there a command line version of GEOGRAPHICLOCATION that I can put in acaddoc.lsp that will rectify this annoyance once and for all.?
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
Had to remove the GeographicLocation and then do a File > SaveAs (and overwrite original) on my template before it would recognise the changes
