Using the stage storage tool works well for basins, but I can not get it to work when the waste starts breaking ground (in fill).
What I need is the solid created between two surfaces, sliced at 1m intervals.
I'm guessing that you have two surfaces, excavated existing ground and a top surface for the waste. If the excavation is a basin then you would be able to get a volume to the surface from that. The second volume could be calculated using the top surface, from the ground up to the top of the pile.
I believe there is a way to create surfaces that would allow for stage storage calculation when the excavation is not a basin but it definitely would not be automated or easy.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
OK, I know some of you guys already have certain ideas about me. What if you visualized this in reverse? Draw a basin that represents this mound of waste upside down. I'll leave it at that for the time being.
Bill
Mark Green
Working on Civil 3D in Canada
Thanks for the feedback,
I tried inverting the facility as you suggested. The volume surface shows the correct capacity (= flat surface / design surface - flat surface / existing ground) but, the stage storage data is about half the capacity.
I think it is caused by the uneven ground profile.
The attached drawing contains the ground and design contours.
