Solved by fcernst. Go to Solution.
Solved by Jay_B. Go to Solution.
The issue your describing sounds the This "Move to Site command deletes the original site" issue I encountered.
Is the dwt your using by chance derived from the OOTB 2014 C3d Acad.dwt ?
I recommend sending in a subscription support ticket to report the issue to Autodesk.
While it has been reported by myself & likely others,this is a very critical function which
seriously cripples work flows.
Please also consider submitting direct product feedback to Autodesk re: this issue at the following link:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
It's been reported that dwt's created using the 2013 Acad.dwt do not exhibit this behavior.
The more people that let Autodesk know of this problem the better the chances that maybe it will be considered important enough to fix in a future Service Pack.
I had a problem drawing that deleted feature lines when running the Audit command... I lost a lot of work.
Support told me to get everything out of there and into the NCS.dwt. Once doing that I never had the problem again in the NCS.dwt based drawing.
I think something happened to all of the acad templates in 2013 that messed things up.
If you do not want to use the NCS template find an old 2012 version of acad.dwt and insert your template into that. Configure the C3D drawing settings and you should be set to go.
John Mayo
