Civil 3D Forum
Sites are being duplicated
13 REPLIES 13
Message 1 of 14
ToddRogers-WPM
637 Views, 13 Replies
I have a customer that has a drawing that keeps duplicating sites and putting feature lines on top of each other.  What would be causing this?
Todd Rogers
13 REPLIES 13
Message 2 of 14
troma
in reply to: ToddRogers-WPM
I don't want to be insulting, but I would suspect user error.  Possibly indiscreet use of select similar, or something along those lines?
Mark Green
Working on Civil 3D in Canada
Message 3 of 14
ToddRogers-WPM
in reply to: troma
No we have ruled that out already.  It seems that the AUDIT command is recreating the site and duplicating the feature lines.
Todd Rogers
Message 4 of 14
wfberry
If you haven't done a "repair of the installation", I would do that first.
Bill
Message 5 of 14
ToddRogers-WPM
in reply to: wfberry
That's already be done.
Todd Rogers
Message 6 of 14
tcorey
Todd, I don't have an answer, but I would be curious to know: Does the same thing happen with RecoverAll? With Fix errors turned off in Audit? Possibly the Audit routine is finding fault with the Site and the duplication is its attempt to re-create the defective object? This doesn't happen to other drawings, right?
If you wblock the entities that make up the Site, do you get the same error when you audit that drawing?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 7 of 14
jmayo-EE
Maybe they are coping and pasting FLines into the file. If you copy a fl and paste it on top of the original you will wind up with a duplicate site.
John Mayo
Message 8 of 14
ToddRogers-WPM
in reply to: jmayo-EE
You know guys, it's really hard to tell what exactly is causing this.  The reason I say this is that the customer never tells you EXACTLY what they have done.  You ask them if they do something and they say no, then you find out later that they did do it.  I'm going to mark this one up as "user error".  Thanks for the feedback guys.
Todd Rogers
Message 9 of 14
tcorey
Todd, I'm sure you and I could swap stories for hours... Smiley Wink
Tim Corey
Redding, CA
Message 10 of 14
ToddRogers-WPM
in reply to: tcorey
I don't know if they would be stories or rants...LOL!!
Todd Rogers
Message 11 of 14
tcorey
I'll bet this is the reason. It makes sense. Many people routinely use copy/paste without knowing the consequences.
For anyone needing a workaround: copy and paste polylines and then create feature lines from them.
Tim Corey
Redding, CA
Message 12 of 14
troma
in reply to: tcorey
Or just copy/paste the FL, but know that you have to 'Move to Site' afterwards.
Mark Green
Message 13 of 14
sboon
When the Audit runs does it actually report that it fixed anything, or does it just duplicate the site?
Steve
Expert Elite Alumnus
Message 14 of 14
ToddRogers-WPM
in reply to: sboon
It sure does.  Says there is 6 errors fixed.
Todd Rogers
Rail Community
