Help - I am trying to create a corridor with the following parameters: single lane that picks up the superelevation from the alignment. I have built the superelevation into the alignment, and I understand that I need to use a subassembly that auto picks up the alignment's superelevation (like "LaneInsideSuper). How exactly do I use this subassembly when the corridor is based on one single-sloping lane? If I use the above subassembly it uses the alignment's superelevation, but throws that slope on each side of the alignment (which is running about 4'-0" off the centerline of my corridor). How do I get this to work? Thanks for any help!
Steve Blackburn
Frost Engineering
Not sure what you mean by [throws that slope on each side of the alignment]. Try the LaneOutsideSuper as well.
