Civil 3D Forum
Single Corridor crossing multiple surfaces
4 REPLIES 4
272 Views, 4 Replies
Hi all,
I have a subdivision that is partially graded. I have the existing ground surface and a new surface of the graded section.
I need to push a road corridor through both the graded and ungraded property which means the corridor will need to go from the graded surface to the existing surface.
Can this be done? If so, then how. If not then are there any alternative methods to accomplish this task?
4 REPLIES 4
I assume you're just asking about the target surfaces, and well all know
about assumptions. So, if I am correct, simply create two regions, and set
the target surfaces accordingly. This will let your corridor tie-in as
needed.
James Wedding, P.E.
Engineered Efficiency, Inc.
Civil 3D 2007
XP Tablet, SP2, 2GHz, 2G
www.eng-eff.com
www.civil3d.com
I understand regions as it applies to solids, but I am not familiar with regions as it applies to Civil 3d surfaces.
Could you please expand on this? explain, example, etc.
You can tell your corridor to have several different regions.
Each corridor region can be told to target a different surface.
Pick your corridor>Right Click>Corridor Properties
wrote in message news:5179543@discussion.autodesk.com...
Dana,
Thanks for the help !
Rail Community
