I created an empty TIN surface, created some 3D feature lines from polylines, edited the feature lines with elevations, then added them to the surface as breaklines. There's an approx 25 foot distance between two feature line elevation points set on an arc, which is also the approx surface outer boundary. Triangulation does not cleanly follow the arc, there is a gap on the inside of the arc. Also the surface appears to overrun the other side of the boundary. See graphic.
The magenta polyline is the outer surface boundary. How can I get the surface to cleanly follow these arcs without lots of intermediate points? Can I get it to interpolate elevations along the arcs?
Solved by Jeff_M. Go to Solution.
