Civil 3D Forum
Simple Surface from Feature Line (Break Line) Question
2 REPLIES 2
8250 Views, 2 Replies
I created an empty TIN surface, created some 3D feature lines from polylines, edited the feature lines with elevations, then added them to the surface as breaklines.  There's an approx 25 foot distance between two feature line elevation points set on an arc, which is also the approx surface outer boundary.  Triangulation does not cleanly follow the arc, there is a gap on the inside of the arc.  Also the surface appears to overrun the other side of the boundary.  See graphic.
The magenta polyline is the outer surface boundary.  How can I get the surface to cleanly follow these arcs without lots of intermediate points?  Can I get it to interpolate elevations along the arcs?
2 REPLIES 2
Jeff_M
When adding breaklines, set the mid-ordinate ditance to a smaller value. I use 0.02 most of the time, in tight parking areas I'll shrink that further. You can set the defaults for this so you don't hvae to think about it everytime:
in reply to: Jeff_M
works like a champ, thank you!
Rail Community
