Depends on how you are creating them. if you use pick points you can skew
them as you place them. Otherwise just select them after creation, two
grips appear, a triangle which will lengthen or shorten and a square grip,
move the grip to skew the section(If you have dynamic input on you should be
able to tab over and enter an angle) The other way is to use the edit
sample line command from the sample line toolbar.
Nick Zeeben
Engineered Efficiency
C3D 2007 SP1
XP Tablet and Pro
wrote in message news:5224672@discussion.autodesk.com...
How can you skew your sample lines to your alignment?
Thanks...
Adam M., EIT
