Civil 3D Forum
Simple Linetype issue, need help!!!
7 REPLIES 7
Message 1 of 8
hworth18
623 Views, 7 Replies
Sorry to sound like a noob, but I can't seem to find a fix for this issue.
I have a base drawing that is xref'd into multiple alignment sheets. The linetypes on the base vary such as center of road, water lines, gaslines and such. All of my linetypes have the same Ltscale of 150.00 and all show up correct in paperspace except for one that comes out as a continuous line. and no matter what I have tried, it doesn't change.
 Any suggestions?
My settings for all polylines are:
color: by layer
linetype: by layer
linetype scale: 150.00
lineweight: by default
global width: 1.0
elevation: 0.000
The scale on the alignment sheets is 1"=500'
Harry
7 REPLIES 7
Message 2 of 8
sjg
in reply to: hworth18
Try PSLTSCALE = 0
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Message 3 of 8
hworth18
Hi Steve,
 Thanks, but the PSLTSCALE is already set to 0, any other suggestions?
I have already tried setting psltscale at 0 and 1, and also adjusting the ltscale from 1 to 500 with no success, that is why this has me stumped.
Message 4 of 8
Sinc
For the most-common usage, you would have all your object linetype scales set to 1.  Then set MSLTSCALE = 1, PSLTSCALE = 1, and LTSCALE = 1 or LTSCALE = 0.5.
Sinc
Message 5 of 8
CIVIL-SOUTH
Double check the *.lin file to make sure it has the correct data assigned to that linetype.
Message 6 of 8
hworth18
I got it fixed, thanks so much for your input!!
Message 7 of 8
blt
What was your fix?
Bryan Thorp, PLS
Civil 3D 2017 SP1
Dell OptiPlex 990 Workstation
Intel I7
16 Gig of RAM
Message 8 of 8
hworth18
Since the alignment sheets were not recognizing that linetype from the xref, I did a  simple copy/paste on a portion of the line into modelspace which inserted the linetype into the drawing.
Rail Community
