What is the trick to get them not to overlap? I have a three sided box, it's actually the top of a 'U' shaped berm. The inside of the berm needs to project down to the surface at a 1:1 slope. The outside of the berm needs to go down on a 2:1, or maybe even a 3:1. The 'U' is 6' across for its length. What's the trick?
Solved by Neilw_05. Go to Solution.
When you apply the grading, choose No when promtped to apply the entire length and then set start and end points for the region you want to be 2:1. Repeat for the 1:1 region. Leave gaps between the regions and apply a transition grading to fill them in.
I just came here to post this, but now I have another thing to try. So I guess I'll be googling "transition grading" now. My problem is selecting the corners that are shared between the two gradings. I guess I don't do that.
Here is where I'm at, before trying the "transition grading."
Your Name
Your Name
