By rt-clicking on the EG surface in my sections I get the opiton for "Edit
Labels". The Type that includes your CL elev. and offset is "Grade Breaks"
then "FG Sections". If you're still not getting a label for CL is could be
that the subassembly you are using didn't include a code at that location.
You can add a MarkPoint (from the Generic assembly Tool Palette) to place a
code at the CL. You'll want to specify the code name and point code in the
properties set during placement. You might want to use an exisiting code
like "Crown". The Code Set Styles are on the Settings tab of the Toolspace
under General<<
parameters for the sub-assemblies display and label within the assembly (but
not especially the Section View). You'll want to pay attention to which
Code Sets you're specifying throughout the Corridor and Seciton View
creation process. They are "dynamic", however, and can be changed at any
time once you find the right areas to do so.
Hope this helps,
JD
