Civil 3D Forum
(-) sign pulls up drawing menu
2 REPLIES 2
369 Views, 2 Replies
Everytime I use keyboard commands that include a - sign, Civil3D always opens up the drawing menu.
For example, if I want to use the layer menu, I typically would put in -la to manage my layers via text commands
However, when I hit - , the drawing menu loads up and I need to escape from it (hitting the escape button 3 times!) before I can continue on my keyboard commands.
Is this a setting that I can turn off somewhere?  Thank you.
2 REPLIES 2
gccdaemon
I get the same problem. Normally with keyboard shortcuts you'll be able to modify them in the CUI, but I think this may be tied to default windows functions and may be accessable through registry only. Can someone from autodesk chime in?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Jeff_M
in reply to: gccdaemon
There's a thread in the Acad2011 forums about this, with what appears to be a workaround:
http://forums.autodesk.com/t5/AutoCAD-2011/dash-key-goes-to-menu/m-p/2690027#M2584
Rail Community
