I'm having big issues trying to get a .SID picture to plot. The .SID shows up in the print preview page, but then never makes it to the plotter. Any ideas?
Solved by GreeneSWCD. Go to Solution.
Out of curosity does the printer print eveything but the image, or does it not print anything at all?
yep, it prints everything but the .sid. It even shows the .sid in the print preview window.
I was hoping it was something easy like the layer with the .sid in it was set not to plot, but no dice.
I can get it to come through and print every once in a while after a restart. So that just makes it even more mysterious. Could it be a hardware problem? Like the network cable from my computer to the plotter can't carry that much data?
My first thought is that the plotter doesn't have enough memory to handle the image.
Don Ireland
Engineering Design Technician
1] plot to a .PDF file
2] open it with Adobe Reader: if the PDF contains the .SID background, send it to the plotter
We wait for the result, good luck!
I've also tried plotting to pdf, but no luck there either. The plot thickens.... (pun intended, ha!)
