jmayo
Message 41 of 47 (251 Views)
Re: Showing breaks in Profiles
10-11-2011 03:52 PM in reply to: jmayo
"We only need to label surface profiles like they we layed-out profiles if a surveyed.."
Wow. That should be, We only need to label surface profiles like they were layed-out/FG profiles if a surveyed...
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Joe-Bouza
Message 42 of 47 (242 Views)
10-12-2011 04:33 AM in reply to: jmayo
:smileysurprised: These things happen. You beat Bill to the punch though :smileytongue:
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Joe-Bouza
Message 43 of 47 (241 Views)
10-12-2011 04:42 AM in reply to: Jeff_M
Hi Jeff - I'm still confused. My questions to clarify the intent were not answered very clearly.  And the ratio of views to replies indicates how vague this was
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
troma
Message 44 of 47 (233 Views)
10-12-2011 06:04 AM in reply to: jmayo
Joe, I guess I have some humble pie to eat.  That does work.  I was wrong to say it didn't.
My only objection to this method then is the same as my objection to John's: it involves the creation of a FG or 'proposed' surface, and running a profile on it.  This is cumbersome: it adds a lot of data to the drawing and slows the program down.
(In 2008 C3D, when profiling a surface, if you added labels to that profile, closed out of the drawing and reopened, the labels disappeared.  The only labels that would stick around were the ones on a "layout profile"; i.e. one drawn in profile view, not from a surface.  I presume this has been fixed by now, but I haven't tried it in a long time.)
I suppose the only other way around this is to have multiple profiles.  One plots, the next doesn't, the next one does etc.  Sounds like a nightmare for design I know, but you could add (small) non-plotting grade labels too, so that you can visually see that one profile is connected to (snapped to, or has the same end point as the next's start point) and at the same % grade as the next one ( and therefore could be 'driven' etc as one continuous profile).  And it gives you the flexibility of plotting, not plotting, adding one label set to the plotting ones, a different label set to the non-plotting.
Still not sure which I'd prefer; that one I just said or the CONVERTLINEWORKTOMASKBLOCK.  But I'm sure I wouldn't want to use a surface profile.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Joe-Bouza
Message 45 of 47 (224 Views)
10-12-2011 07:26 AM in reply to: troma
Troma, I'll have a slice with you. The whole time I had the impression that surface profile were what was being targeted for solution.
"What a long strange trip its been" :smileywink:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Distinguished Contributor
wdbar
Message 46 of 47 (196 Views)
11-30-2011 12:01 PM in reply to: jmayo
Good discussion and much confusion!
I was looking for a solution in there somewhere but never saw it.
Is there a way to maintain the labels of a profile when it has been broken (erased a tangent or VC)?
The only solution I can see currently is to CONVERTLINEWORKTOMASKBLOCK a tangent between the breaks.  I'm currently fighting the pain of having to insert breaks in a long profile that has been labeled and made pretty.  I lose all labels upstation.
troma
Message 47 of 47 (177 Views)
12-06-2011 09:21 AM in reply to: wdbar
I thought I'd tried that, and read back a little.  It's there in message #29 of the discussion: doesn't work.  Won't add labels to any part past the break, though it does consider it part of the profile when you select it.
Don't mess up your drawing, especially if you've already prettiefied it!  The mask is the only way I know of.
(Unless you want to just explode all your labels and explode the profile.  Then you can just delete as much as you like!  You've also sunk your self for any future revisions to alignment/profile/assembly/corridor......)
Come on AutoDesk, there's got to be a better way to handle this!
