AutoCAD Civil 3D General Discussion
wbrustle
Message 1 of 3 (487 Views)
showing a volume surface in color
487 Views, 2 Replies
04-29-2013 11:59 AM
I am totally lost and need help finding a tutorial explaining how to make a color rendering showing cut and fill on a volume surface. I keep reading bits and pieces of how to do it, but nothing explaining a step by step process. The terminology keeps referencing elevation ranges??? I figured out how to create a volume surface, but now desire to print out a colored drawing showing the cut and fill areas. Any help would be appreciated
*Expert Elite*
neilyj
Message 2 of 3 (478 Views)
Re: showing a volume surface in color
04-29-2013 12:47 PM in reply to: wbrustle
Like this http://www.thecadmasters.com/wordpress/index.php/2011/05/02/civil-3d-2012-elevation-banding/ or this http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Cut-and-Fill-Labelling/td-p/3100198 or this from help http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-A55C7D93-AF19-4EAE-8028-EEECDD0...
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
autoMick
Message 3 of 3 (437 Views)
04-30-2013 04:57 AM in reply to: neilyj
The volume surface is simply the elevation difference between your base and comparison surfaces, so if at a particular x,y point the difference between the two surfaces is +2m, then that is the z value of your volume surface at that point. The volume surface is just the same as any other surface in terms of presentation. The elevation ranges (and colour scheme) for your volume surface will correspond to the depth of cut or fill required to achieve the comparison surface.
Infrastructure Design Suite Premium 2015 SP1
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), Win7Pro64, Quadro K4000 (and another with GTX680)
Announcements
Need installation help?
