Civil 3D Forum
showing a volume surface in color
2 REPLIES 2
wbrustle
1436 Views, 2 Replies
I am totally lost and need help finding a tutorial explaining how to make a color rendering showing cut and fill on a volume surface. I keep reading bits and pieces of how to do it, but nothing explaining a step by step process. The terminology keeps referencing elevation ranges??? I figured out how to create a volume surface, but now desire to print out a colored drawing showing the cut and fill areas. Any help would be appreciated
2 REPLIES 2
neilyj666
in reply to: wbrustle
Like this http://www.thecadmasters.com/wordpress/index.php/2011/05/02/civil-3d-2012-elevation-banding/ or this http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Cut-and-Fill-Labelling/td-p/3100198 or this from help http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-A55C7D93-AF19-4EAE-8028-EEECDD0...
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
autoMick
in reply to: neilyj666
The volume surface is simply the elevation difference between your base and comparison surfaces, so if at a particular x,y point the difference between the two surfaces is +2m, then that is the z value of your volume surface at that point. The volume surface is just the same as any other surface in terms of presentation. The elevation ranges (and colour scheme) for your volume surface will correspond to the depth of cut or fill required to achieve the comparison surface.
Civil3d user in Australia since 2012.
Rail Community
