i copied the parameter SE from other label and pasted it in the alignment horizontal PI or curve label but it shows "???" one project requires us to display SE value per circular curve or SCS on plan view. right now it's type in. Anybody knows how to do it?
An alignment represents a plane geometrical series of entities. I don't see how it would have any idea about a superelevation of a corridor. The corridor just follows the alignment.
That's the way I see it.
Now I believe that you should be able to type in any text using the label composer of any label, in your case use the P.I. label.
Bill
not the instataneous SE. i need the full super value through the circular portion. the SE parameters are part of alignment objects or hierarchy. I thought i used to be able to do this. I could be wrong.
SE is not part of corridor.
that's what we are doing is typing in. then they decided to add one more line to all and then i had to retype. once a label gets override not style change can control it anymore.
