I'm using 14 and I'm not sure when it happened, but I recently noticed that when I select a line or pline, the bearing is no longer shown in the properties tab. Not sure how I could've changed a setting but it happens...
Any help is appreciated.
Matt
Solved by Jay_B. Go to Solution.
What happens if you enter UNITS @ command line and switch the Angle Type to "Surveyor's Units"?
